Satriaji's avatar
Satriaji
Icon for Cirrus rankCirrus
Apr 26, 2019
How to GREP Monitor Status Spesific Pool or VS in Range Time
Good Morning Guys ....
Are you know the commands if I want to grep monitor status spesific pool or vs in range time ? Im Using F5 BIG-IP Ver.12.x.x . (ex : Pool_HOST_SIMOL3K from 1.00 AM - 7.00 AM date 26 April)
Usually Im just using commands : tail -10000f /var/log/ltm | grep monitor ==> for monitoring
But, I want to grep monitor spesific pool with range time . Anyone knows whats the commands ? Thx so muchh !!
  • Hi,
    you can use this command:
    See between a specific range time:
    sed -n '/Apr 26 03:25:03/,/Apr 26 04:14:32/p' /var/log/ltm
    See between a specific range time with condition (grep: status and pool name):
    sed -n '/Apr 26 03:25:03/,/Apr 26 04:14:32/p' /var/log/ltm | grep "status down" | grep "Pool member"
    keep me in touch
    regards
    • Satriaji's avatar
      Satriaji
      Hii Yosefff,
      I try your command at CLI like pics bellow.
      Are this comment saved at another location folder ? its different location with ltm.gz at /var/log/ltm right ? That comment will capture spesific range n pool member name with status down, right ? How can i get that log file saved ? I think it will appear at CLI directly.
      Thankkyouuu ...
