07-Feb-2020 19:56
Hello All,
We have created irule to unblock the Geo-location for few IP address. But we are facing the challenge with remote logging.
We have used ASM_REQUEST_DONE in irule. It means ASM already processed the request and generated the log in the back end the same log is forwarded to remote logging server as well.. But it's false positive.. We want to send unblocking log to remote syslog server as well.. Please help us on this.
Thank you.
11-Feb-2020 14:31
When logging from ASM using a user-defined format string, there is a field "blocking_exception_reason" that will display "Unblocked from iRule" when ASM::unblock is used.
21-Feb-2020 17:42
Hi Blakely,
Thank you for the response.
The issue has been resolved with help of BIG IP logs.
Thanks & Regards
Ramana T
