Technical Forum
How to Create IRule to divert traffic between Pools based on XFF Header
Raunak_Tiwari
Hello Everyone,
I am facing issue with my Irule, Natted Traffic is coming from Imperva WAF and i have take value Value of XFF Header to redirect traffic to specific pool.
I am receiving HTTPs traffic and i have also enabled SSL Interception on F5 LTM.
IRule that i am using.
if { [HTTP::header "X-FORWARDED-FOR"] equals "<DataGroupName>" } {
pool Federation-ACC-444
pool Federation-ACC-443
Could you help me how i can proceed further, because above IRule is not working.
1 ACCEPTED SOLUTION
Hi Raunak Tiwari,
You should use "class match" for datagroup compare
	if { [class match [HTTP::header "X-FORWARDED-FOR"] equals <DataGroupName>] } {
	else {
https://clouddocs.f5.com/api/irules/class.html
2 REPLIES 2
Hi Raunak Tiwari,
	else {
Raunak_Tiwari
Dear Eaa,
Thanks For your help,
Small change i have done in IRule.
I have used Incap-Client-IP at place of XFF Header.
Imperva supports both headers but in my situation it was using Incap-Client-IP
https://support.incapsula.com/hc/en-us/articles/200627650-Detection-and-Location-of-Real-Source-Clie...
