RAQS's avatar
RAQS
Icon for Cirrus rankCirrus
Aug 28, 2019
How to automate LB VIP Creation
Hi Team,
Greetings for the day!
How can i automate LB VIP creation (Full setup - like to deploy new application behind LB.). Is this can be done via any script ot by F5 itself ? Or, do i need to get a third party tool
Regards,
ShashankS
  • You can script it using iControlREST or you could use something like Ansible or Terraform as 3rd party tools.
    All depends on your trigger, what will happen to require a new VS to be configured on the F5 in question?
  • Hi Andy,
    Thanks for reply,
    Can you please guide me , on how i can achieve this with iControlREST
    Requirement is to automate the full steps of deploying application behind LB. (Like creating node , creating pool members , creating pool , creation of vip and apply required features like LB method , persistence ,binding certificate.
    Regards,
    ShashankS
  • Best resource to get started is here: https://clouddocs.f5.com/api/icontrol-rest/
    Also look at the code shares and articles here on DevCentral for a load of resource and help with iControl.
    Warning: The older 'iControl' uses SOUP where iControl-Rest uses REST, iControl-Rest is recommended but if you find an article on iControl it may be using SOUP instead of REST.
  • Thanks Andy for sharing an article and sorry for delay response .
    Can you please let me know where should i run below code :- (like normally we run on CLI of F5)
    curl -sku admin:admin https://<host>/mgmt/tm/ltm/virtual -H "Content-Type: application/json" -X POST
    -d '{"name": "vs", \
      "destination": "10.10.10.10:10", \
      "mask": "255.255.255.255", \
      "pool": "CentOS-all80", \
      "persist": [ {"name": "cookie"} ], \
      "profilesReference": {"items": [ {"context": "all", "name": "http"}, {"context": "all", "name": "tcp"}, {"context": "clientside", "name": "clientssl"}] }, \
      "rules": [ "ShowVersion" ], \
      "sourceAddressTranslation": {"type": "automap"} }'
    Regards,
    ShashankS
