Technical Forum
Custom Alert Banner
high voltage on GBIC
neeeewbie
MVP
MVP
Hi guys
I need your help !
I know how to show ddm value (voltage, dbm), etc)
log automatic displaying when gbic received high voltage ?
or need manual checking ??
Please let me know if you know that ~
thanks
1 ACCEPTED SOLUTION
Hello Neeeewbie.
You can use DDM to check your power thresholds.
Transmit and Receive Power Thresholds
Transmit Low Alarm Threshold 0.1000mW -10.00dBm
Transmit High Alarm Threshold 3.1623mW 5.00dBm
Transmit Low Warning Threshold 0.1585mW -8.00dBm
Transmit High Warning Threshold 1.9953mW 3.00dBm
Receive Low Alarm Threshold 0.0398mW -14.00dBm
Receive High Alarm Threshold 2.1878mW 3.40dBm
Receive Low Warning Threshold 0.0794mW -11.00dBm
Receive High Warning Threshold 1.7378mW 2.40dBm
REF - https://support.f5.com/csp/article/K83253027
Regards,
Dario.
Regards,
Dario.
3 REPLIES 3
Hello Neeeewbie.
Knowing how to extract that value, you can configure a custom MIB to report that state.
https://support.f5.com/csp/article/K13596
Also, you can configure a periodic iCall to monitor that value and log a message when the issue occurs.
Regards,
Dario.
Regards,
Dario.
Hi
thank you but we don't know what value is show dangerous ,, do you know the dangerous value ?
Hello Neeeewbie.
Regards,
Dario.
Regards,
Dario.
