26-May-2020 11:51
Hi All ,
Is there any option to find which process is using the more cpu , as we can see for tmm.0 it shows 118% , can we find out what causing the tmm.0 to go up ?
Swap: 5242876k total, 0k used, 5242876k free, 2956952k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
18298 root 1 -19 8549m 82m 61m R 118.8 0.5 79279:13 tmm.0
21723 root 39 19 195m 128m 8720 S 74.3 0.8 1:30.87 java
19329 root 20 0 2342m 277m 24m S 53.9 1.7 3389:31 bd
13582 root 20 0 48936 29m 15m S 36.5 0.2 67574:52 bigd
19346 root 20 0 115m 46m 31m S 29.7 0.3 421:18.84 pabnagd
6989 root 20 0 177m 117m 25m S 3.6 0.7 6823:17 mcpd
17797 root 20 0 175m 151m 20m S 3.6 0.9 4175:09 asm_start
5672 root 25 5 113m 27m 22m S 1.6 0.2 3715:39 merged
cpu_id five_sec_avg.ratio
0 72
1 96
2 71
3 84
Sys::TMM: 0.0
Global
TMM Process Id 18298
Running TMM Id 0
TMM Count 1
CPU Id 0
Memory (bytes)
Total 6.5G
Used 3.3G
CPU Usage Ratio (%)
Last 5 Seconds 61
Last 1 Minute 59
Last 5 Minutes 57
Sys::TMM: 0.2
Global
Running TMM Id 2
TMM Count 1
CPU Id 2
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 53
Last 1 Minute 51
Last 5 Minutes 50
27-May-2020 14:40
probably check with support, I believe some versions had a reporting bug. That number is supposed to be divided by the number of cores and I think some versions had a miscalculation
