Technical Forum
Help with IRule Client Auth Certs
Mr_Moody
I have an IRule below that I'm working on. My intent is to enforce client certificate authentication on two URI's only and if any client certificate errors should result in a redirect to a custom error page. The VS has a SSL profile set to 'ignore' client certificates. This rule successfully processes the first two 'If' statements. The problem is that the custom error page is not displayed. Any help would be appreciated.
	if { not ([HTTP::uri] starts_with "/uri1") || ([HTTP::uri] starts_with "/uri2")} {
			return
if { ([HTTP::uri] starts_with "/uri1") || ([HTTP::uri] starts_with "/uri2")} {
		SSL::session invalidate
    SSL::authenticate always
    SSL::authenticate depth 9
    SSL::cert mode require
    set cmd "SSL::profile /Common/require_clientssl"
    eval $cmd
    SSL::renegotiate
if {[SSL::verify_result] == 0 }{
			return
HTTP::respond 302 Location "http://error.com/error.html" Cache-Control No-Cache Pragma No-Cache
I have another rule that meets two of the three requirements. With the VS SSL profile set to 'request' client certs. This rule does provide a custom error page when Cert errors occur on the two named URI's. But it also results in a certificate prompt for users who access other URI's due to the default SSL profile setting.
			return
			return
1 ACCEPTED SOLUTION
Simon_Blakely
F5 Employee
F5 Employee
Your HTTP::respond 302 is in the else clause of your second if statement.
It is never reached.
                        # This path has no client-authentication
			return
      # perform client-authentication if the uri matches
        eval $cmd
        SSL::renegotiate
        # we cannot execute this path because of the first *if* statement
			return
Try something like
      # we don't need to renegotiate with client-authentication
	  return
      # we do need to renegotiate with client-authentication
      eval $cmd
      SSL::renegotiate
      # check if renegotiation with client-auth succeeded
		return
but I haven't tested this to check ...
2 REPLIES 2
Simon_Blakely
F5 Employee
F5 Employee
			return
        eval $cmd
        SSL::renegotiate
			return
Try something like
	  return
      eval $cmd
      SSL::renegotiate
		return
Thank you that was it! I also had to change the cert mode to 'request'.
