03-May-2020 12:20
Hi folks,
Need your advise on creating an irule for the below requirement
need to block the following uri cloud.du.ae/cloud/* with an exception if SAML appears in the URI
like lets say cloud.du.ae/cloud/abc/saml should be allowed but all other URI's with /cloud should be blocked
Thanks in advance.
03-May-2020 14:55
Use a Local Traffic Policy with a First Match strategy.
K15085: Overview of the Local Traffic Policies feature (11.4.0 - 12.0.0)
Create a rule with conditions
hostname is cloud.du.ae
HTTP URI begins with cloud
HTTP URI contains saml
that forwards traffic to the pool
Create a second rule to redirect requests starting with cloud to somewhere else (or drop the request)
Finally add a final default rule that forwards all requests to the pool.
Order your rules so that they match in correct order:
05-May-2020 07:23
Works perfectly. Thanks a lot Simon 🙂
