Dominic
Sep 22, 2017Nimbostratus
Filtering specific cron messages from syslog with F5 11.6
I have a custom syslog filter which I am attempting to get the filter out cron messages with level info.
Example I wish to filter: F5_NAME info crond[11244]: (syscheck) CMD (/usr/bin/system_check -q)I want all other facilities info messages sent as normal.
Output of list /sys syslog all-properties:sys syslog {
auth-priv-from notice
auth-priv-to emerg
console-log enabled
cron-from warning
cron-to emerg
daemon-from notice
daemon-to emerg
description none
include "
filter f_remote_loghost_level {
level(info..emerg);
filter f_remote_loghost_cron {
not (facility(cron) and level(info));
filter f_ssl_acc_req {
not (facility(local6) and level(info) and filter(f_httpd_ssl_acc)) and
not (facility(local6) and level(info) and filter(f_httpd_ssl_req));
destination d_remote_loghost {
udp(\"x.x.x.x\" port(514));
log {
source(s_syslog_pipe);
filter(f_remote_loghost_cron);
filter(f_remote_loghost_level);
filter(f_ssl_acc_req);
destination(d_remote_loghost);
iso-date disabled
kern-from debug
kern-to emerg
local6-from notice
local6-to emerg
mail-from notice
mail-to emerg
messages-from notice
messages-to warning
remote-servers none
user-log-from notice
user-log-to emerg
This works is as far as debug is excluded as are f_httpd_ssl_acc and f_httpd_ssl_req. However I still get info level from facility cron. I have also tried filtering on facility as 'crond' from the message and also 'clock' which my syslog server reports as the facility.
My config above is based on these two articles:
K13333: Filtering log messages sent to remote syslog servers (11.x - 13.x) K13317: Configuring the level of information that syslog-ng sends to log files (11.x - 12.x)Can anyone point out what I am missing?
