fan status verification
traveler_94007
I am runnig a BIG-IP 3600 with version 11.2.0 and when try to figure out the fan status I got the following output:
show /sys hardware
Chassis Fan Status
Index Status Fan Speed(rpm)
1 3 9926
2 3 10546
3 3 9926
Shouldn't be an "up" status? Is the status 3 correct or it is just a bug?
Thanks a lot!!
1 REPLY 1
nitass
F5 Employee
F5 Employee
it is cosmetic issue.
Bug 381613 - b platform shows "error" status & tmsh shows "3" status for each fan
