Technical Forum
Faiover issue when the uplink of Active LTM is down
Thiyagu
Altocumulus
Altocumulus
Hello All,
Our LTM did not failover from Active to standby when the uplink of Active LB went down.
Could you please help to setup the failover scenario that when the uplink of Active LTM failed then LTM should failover to the standby LTM?
Regards,
Thiyagu
1 REPLY 1
PeteWhite
F5 Employee
F5 Employee
You need to use the HA groups feature - https://support.f5.com/csp/article/K16947
