Thiyagu's avatar
Thiyagu
Icon for Cirrus rankCirrus
Jan 10, 2020
F5. LTM fail to load a configurtion from UCS
Hello All,
I have tried to load the UCS configuration in the new LTM and it got failed with the below error log.
Could you please suggest with the steps to identify which piece of UCS configuration is causing issue and how to fix the issue?
Installing configuration...
Running ucs_builtin_preprocess
ATTENTION REQUIRED:
  Your previous configuration files have been archived, as listed
  below. If you customized any settings in these files before
  upgrading, you will need to manually restore those changes by
  using the Configuration utility or Traffic Management Shell (tmsh).
  Archiving /config/wa/globalfragment.xml.12.1.3.2
  Archiving /config/wa/pvsystem.dtd.12.1.3.2
  Archiving /config/wa/pvsystem.conf.12.1.3.2
Post-processing...
usermod: no changes
Reloading License and configuration - this may take a few minutes...
Jan 10 01:28:44 localhost emerg load_config_files: "/usr/bin/tmsh -n -g load sys config partitions all " - failed. -- Loading schema version: 12.1.3                         .2 Loading schema version: 12.1.3.5 01070712:3: Failed: name (/Common/dtca.key) Cache path (/config/filestore/files_d/Common_d/trust_certificate_key                         _d/:Common:dtca.key_56648_3) does not exist and there is no copy in trash-bin to restore from. Unexpected Error: Loading configuration process faile                         d.
Jan 10 01:28:45 localhost emerg load_config_files: "/usr/bin/tmsh -n -g load sys config partitions all base " - failed. -- Loading schema version: 1                         2.1.3.2 Loading schema version: 12.1.3.5 01070712:3: Failed: name (/Common/dtca.key) Cache path (/config/filestore/files_d/Common_d/trust_certificat                         e_key_d/:Common:dtca.key_56648_3) does not exist and there is no copy in trash-bin to restore from. Unexpected Error: Loading configuration process                          failed.
Configuration loading error: base-config-load-failed
For additional details, please see messages in /var/log/ltm
WARNING: There were one or more errors detected during installation.
        Check the error messages and take the proper actions if needed.
ERROR: UCS installation failed.
Operation aborted.
Unexpected Error: UCS loading process failed.
Thanks a lot in advance
Regards,
Thiyagu
