Technical Forum
F5 | LTM , application is not working via F5
RAQS
Cirrus
Cirrus
Hi Team,
Hope all are doing good.
I have F5 LTM, on which I configure multiple partition. In one partition i.e aap-dev have configured http LB VIP. But page is not accessible via F5 but it is accessible directly via server.
configuration wise it looks fine. Traffic is coming to F5. I took trace and observed that F5 is picking wrong gateway. In single partition i have default route and static route. Instead of picking static route it is picking default route. How this can be corrected?
Regards,
RAQS
2 REPLIES 2
Are you sure if static route covers the destination that you are looking to match? If not, you can try it by adding specific /32 static route for the required destination and then check.
boneyard
MVP
MVP
did you get this solved RAQS?
