25-Aug-2020 01:14
If i install a pay-as-you-go F5 instance in Azure, is there a way to convert it to a bring-your-own license version?
Or would i have to export the config, create a new F5, and import?
26-Aug-2020 08:23
You'll have to create a new VE, see K72636998 for additional details.
Actions that require you to create a new BIG-IP VE instance
Note: You must refer to your cloud service provider documentation for the additional steps required to create your new BIG-IP VE instance.
Note: For more information about migrating your configuration to a new BIG-IP instance on AWS, refer to K35355528: Migrating an existing AWS BIG-IP instance to a new instance.
