14-Apr-2018 23:09
I am currently following CBT Lab for F5 fundamentals(see attached 2 images) in which F5 imported and configured on Vmware workstation( Ver 13.x).The Internal subnet is 10.2.0.0/24 and Internal IP address on F5 is 10.2.0.145. My question relates to the INTERNAL section of the diagram where there are 3 web server nodes (10.2.0.11, 10.2.0.22 and 10.2.0.33) which I can't ping from F5. All three nodes can ping with each other.
Also F5 internal side and all three web servers are all on Vmnet2.
I would appriciate if somebody can assist me as I have reached a road block.
Anuj
Solved! Go to Solution.
17-Apr-2018 20:06
Hi Anuj,
To me, it looks like VMnet issue rather then the F5 issue. Try swapping VMnet2 with other interfaces.
16-Apr-2018 02:41
run a tcpdump on the 1.2 interface, do you see the traffic enter?
16-Apr-2018 03:27
Tried below command
[root@BIG-IP-test:Active:Standalone] config tcpdump -ni 1.2 tcp port 80 -w/var/tmp/http.cap tcpdump: listening on 1.2, link-type EN10MB (Ethernet), capture size 65535 bytes
16-Apr-2018 03:45
and? what was the result?
i would do it without any filter and to screen first, to check any data is coming in. then perform a ping towards the F5 and see if you see that.
16-Apr-2018 05:09
Thanks for helping me out. I understand you are trying to help but I am beginner with tcpdump and F5 so please don't get upset. I tried the below command with no filters but there is no traffic. please let me if below info is any help otherwise if you can tell me what command to run and I will do that.
[root@BIG-IP-test:Active:Standalone] config tcpdump -ni 1.2 tcp port 80 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 1.2, link-type EN10MB (Ethernet), capture size 65535 bytes
I tried ping again from server to F5 but still can't ping
16-Apr-2018 05:58
please without filter, so no tcp port 80
the general idea is to make sure there is some traffic going on there, i.e. arp, perhaps spanning-tree, although that is doubtful on vmware. but i would like to make sure you don't have a vmware config issue.
17-Apr-2018 05:10
Sorry about the delay, I removed the filter and receiving below arp output
[root@BIG-IP-test:Active:Standalone] config tcpdump -ni 1.2 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 1.2, link-type EN10MB (Ethernet), capture size 65535 bytes 05:04:01.538995 ARP, Request who-has 10.2.0.33 tell 10.2.0.145, length 35 out slot1/tmm0 lis= 05:04:01.829990 ARP, Request who-has 10.2.0.11 tell 10.2.0.145, length 35 out slot1/tmm1 lis= 05:04:02.140067 ARP, Request who-has 10.2.0.22 tell 10.2.0.145, length 35 out slot1/tmm1 lis= 05:04:02.542342 ARP, Request who-has 10.2.0.33 tell 10.2.0.145, length 35 out slot1/tmm0 lis= 05:04:02.830053 ARP, Request who-has 10.2.0.11 tell 10.2.0.145, length 35 out slot1/tmm1 lis= 05:04:03.140270 ARP, Request who-has 10.2.0.22 tell 10.2.0.145, length 35 out slot1/tmm1 lis= 05:04:03.542078 ARP, Request who-has 10.2.0.33 tell 10.2.0.145, length 35 out slot1/tmm0 lis= 05:04:03.829821 ARP, Request who-has 10.2.0.11 tell 10.2.0.145, length 35 out slot1/tmm1 lis= 05:04:04.140054 ARP, Request who-has 10.2.0.22 tell 10.2.0.145, length 35 out slot1/tmm1 lis= 05:04:04.541731 ARP, Request who-has 10.2.0.33 tell 10.2.0.145, length 35 out slot1/tmm0 lis= 05:04:04.829547 ARP, Request who-has 10.2.0.11 tell 10.2.0.145, length 35 out slot1/tmm1 lis= 05:04:05.151254 ARP, Request who-has 10.2.0.22 tell 10.2.0.145, length 35 out slot1/tmm1 lis= 05:04:05.541915 ARP, Request who-has 10.2.0.33 tell 10.2.0.145, length 35 out slot1/tmm0 lis=
17-Apr-2018 06:57
yeah that pretty much indicates some sort of network issue. assuming your big-ip has ip 10.2.0.145 and the servers are 10.2.0.11, .22 and .33.
the big-ip is looking for them, but they aint responding. you need to look at the VMware network level for this. if the others parts are working then it is probably some configuration issue.
17-Apr-2018 07:39
In VMware player or workstation pro, Host-Only network is just for the purpose as the name reads. You use it to establish communication channel between your Host and Guests. This will be suitable for management interface (if no internet connectivity is needed) and external interface so that your host can access VIPs.
Guest-to-Guest communication does not work with Host-Only networking. If you run native instances of web-servers, then you can use Host-Only networking for internal segment, but if you virtualize them, you can not.
With virtualized web-servers, your internal network needs Guest-to-Guest connectivity (BigIP to servers, and servers to BigIP). Your best choice here is to use "Lan Segment" for the respective network adapter.
My own lab on VMware was built as follows:
NetAdapter 1 (Management). NAT for internet connectivity via mgmt interface (a)
NetAdapter 2 (Client-Side/External). Host-Only with host adapter and DHCP disabled
NetAdapter 3 (Server-Side/Internal). Lan Segment 1
NetAdapter 4 (HA). Lan Segment 2
a) NAT also hides the mgmt interface from other folks in same network. If you build
your lab on top of a laptop that you occasionally take to a conference or workplace,
you should never use bridged networking in place of NAT for internet connectivity
With this setup, I could freely pick whether I use VLAN tagging or not. Also the routing can be implemented cleanly as in production-like environments without the requirement to use SNAT. Asymmetric routing issues are avoided by design.
Good luck with the studies and regards,
18-Apr-2018 03:55
Hannes,
Since I am just having issue with the pinging internal servers I have not configured anything else but the internal network. As advised by you I have tried to put the 10.2.0.11, .22 and .33 and my internal interfaces of BIGIP all on Lan Segment 1 and still the same issue. All webservers can ping each other but can't ping the big ip - 10.2.0.145
18-Apr-2018 06:13
Did you set your BigIP VLAN configuration as tagged or untagged? It's possible you have a mismatch
First thing I'd check
21-Apr-2018 18:59
Untagged
17-Apr-2018 07:39
18-Apr-2018 03:55
Hannes,
18-Apr-2018 06:13
21-Apr-2018 18:59
Untagged
17-Apr-2018 20:06
Hi Anuj,
18-Apr-2018 03:51
Tried and still the same issue.
Correction-I think this resolved the issue. Instead of using VMNET2. I changed it to VMNET3 and it starting working.
18-Apr-2018 15:53
We can have teamviewer session if you need, let me know if you want me to come on teamviewer and see what's happening there.
18-Apr-2018 17:40
Also Anuj, can you send your VLAN and Self-IP configs of the LTM? Is the internal interface/vlan tagged or untagged?
18-Apr-2018 03:57
Please see attached my vmware network settings
18-Apr-2018 23:48
hey man I had this same issue with this same lab.
Here's the problem during my issue:
ok so I finally got it.
The default gw on the servers was set to 10.2.0.1 which is the ip for the vmnet2 and not the bigIP interface, which in turn was set to 10.2.0.145.
So i set the gw to 10.2.0.145 and i get the webpages served all right.
The tutorial caused this confusion, I should email keith barker!
Get this checked.
14-Jul-2022 10:54
Hello guys,
I am facing the Same issue, I have tried all the suggestions but nothing is working for me.
Also I checked the default route on these servers and seems okay.
Please suggest.
Below is the tcpdump out I can see. Same issue I am not able to ping these servers but able to ping with the servers.
listening on any, link-type EN10MB (Ethernet), capture size 65535 bytes
10:54:14.324368 ARP, Request who-has 10.2.0.11 tell 10.2.0.145, length 35 out slot1/tmm0 lis=
10:54:15.325247 ARP, Request who-has 10.2.0.11 tell 10.2.0.145, length 35 out slot1/tmm0 lis=
10:54:16.325754 ARP, Request who-has 10.2.0.11 tell 10.2.0.145, length 35 out slot1/tmm0 lis=
10:54:17.326165 ARP, Request who-has 10.2.0.11 tell 10.2.0.145, length 35 out slot1/tmm0 lis=
10:54:18.326456 ARP, Request who-has 10.2.0.11 tell 10.2.0.145, length 35 out slot1/tmm0 lis=
10:54:19.326335 ARP, Request who-has 10.2.0.11 tell 10.2.0.145, length 35 out slot1/tmm0 lis=
^C
6 packets captured
6 packets received by filter
0 packets dropped by kernel
Thanks.
14-Jul-2022 10:58
Also tried changing the VMNET's but still not working.
