awan_m's avatar
awan_m
Mar 01, 2023
F5 edge client with OIDC and yubikey
Hi All
i am implementing oAuth with OIDC - it is woking fine when logging on through the browser but failing when trying edgeclinet - i have configured oAuth setting on the connectivity profile but it is stil failing .
my oAuth provider is Forgerock .
any suggestions?
  • Hey awan_m - FYI I've asked a teammate to come help answer your question if nobody else drops some knowledge here soon.
  • awan_m's avatar
    awan_m
    Thanks - in my case - i have setup 0Auth with - openID - and it works fine in the browser , meaning yubi key works fine when authenticating through browser - but it fails when i try with Edge clinet - can someone help in that regard
    thanks
    • awan_m's avatar
      awan_m
      thanks for this - my authentication provider is forgerock and oAuth with openid is working -
      the problem is the Edge client - as you showed in your video it should open the browser and authenticate and VPN should establish - and that happens - but it also opens its embidded browser where yubikey fails.
      Question how do i configure it in a way where iy does not open the embidded browser?embedded
      • Matt_Dierick's avatar
        Matt_Dierick
        If the embedded browser opens, it means OIDC edge client config is wrong. It should open a real browser window.
        Check your edge client config.
