Technical Forum
F5 BIG-IP LTM VE - disk space issue
peter_siman
We do have a cron job running which updates a CRL file on regular basis in order to allow F5 to use up to date CRL file for verification of client certificate during mTLS.
What we have noticed is, that the HDD space is constantly being filled up.
We did some investigation and we found out, that there are always files being created in the ./config/filestore/.trash_bin_d/ folder
Please see below an example
ls -lh ./config/filestore/.trash_bin_d/.backup_1597885592_196_d/Common_d/certificate_revocation_list_d/:Common:trust2408-full_88715_317
ls -lh ./config/filestore/.trash_bin_d/.backup_1597885592_196_d/Common_d/certificate_revocation_list_d/:Common:trust2408-prod_79040_294
trust2408-prod / trust2408-full are the certificate revocation lists created by the script.
This is causing, that the file system below is full and F5 can no longer operate properly
Here is a difference within 24 hours
Status from 19/08/2020
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vg--db--vda-set.2._config 2.1G 467M 1.5G 24% /config
Status from 20/08/2020
/dev/mapper/vg--db--vda-set.2._config 2.1G 805M 1.2G 41% /config
I see that there are 10 files generate in less than 24 hours, each file has 43M.
At the end of the day it will eat up all free space and cause F5 to not function properly any longer.
I would expect, that these files which are in "./config/filestore/.trash_bin_d/.backup_nnnn " foler are automatically removed by F5 on regular basis. Or am I missing anything here?
We do have 4 F5 load balancers which have this script enabled and only 2 of them have this issue. All the setup is the same.
Has anyone experienced anything similar? Any advice is highly appreciated.
2 REPLIES 2
LB
Cirrus
Cirrus
What does your script look like?
Hello Peter.
Usually, the folder '/config/filestore/.trash_bin_d' is used to store files when the execution of some transaction fails. If you see files there, normally points that the script could be failing in some step. Information in this folder is completely removable, so you could include some sentence like this in your script:
rm -f /config/filestore/.trash_bin_d/*
But you can also try with this:
https://cdn.f5.com/product/bugtracker/ID513483.html
Debugging your script is also a good point.
Regards,
Dario.
Regards,
Dario.
