10-Mar-2021 05:52
Dear Tech Community,
I have BIG-IP i5000 series appliance in HA cluster active\passive running v14. I noticed there is a second boot location in my BIG-IP running v16. I changed my boot location to v16 and rebooted my appliance as requested and now after the reboot my LCD panel shows "SECURE MODE" offline.
I no longer have access to Management IP also the LCD panel dose not show any options for configuration.
Can anyone please advise how to recover from this situation.
Thank you
Bujar
10-Mar-2021 13:40
OK - the LCD display issue is
K03310534: The LCD on BIG-IP iSeries platforms may become unresponsive following a system restart
You will need to request an EHF to resolve that.
Maybe the 16.x partition has only default config (IP address 192.168.1.245), or does not have a license.
Did you reactivate the license before the upgrade attempt, and transfer the config?
As for recovery, I'd recommend getting a physical console (serial) cable on to the device, and use that to reboot back into the 14.x partition via grub.
If you want to upgrade to 16.x, I'd recommend deleting the existing 16.x volume, and re-doing the upgrade to ensure that the current config is applied to the 16.x volume (with a recently reactivated license).
11-Mar-2021 05:06
Hi Simon,
Yes, I did activate the license before switching boot location. For now I have opened a case with F5 support, I keep this post updated.
Thank you
Bujar
10-Mar-2021 13:40
Hi Bujar,
try to connect via serial console. This sound pretty much like a know bug:
Bug ID 939249: iSeries LCD changes to secure mode after multiple reboots
Afterwards use switchboot to go back to BIG-IP v14:
K5658: Overview of the switchboot utility
KR
Daniel
11-Mar-2021 05:08
Yes Daniel, I tried the F5 support suggested the same article however without success.
I'm waiting for further instructions from F5 support, that's see what they have to say.
Thank you
Bujar
13-Apr-2021 00:56
Hi Bujar, did you get any help from F5? - we have the same issue and the KB article still has no fix or workaround listed. Thanks
13-Apr-2021 02:41
Hi Stephen,
We solved the problem by resetting BIG-IP to factory defaults using following article.
https://support.f5.com/csp/article/K13127
Considering time limitation that we head to get the BIG-IP up and running again, and since there was no need to keep the existing configuration we simple reset the configuration to default. However this may not be best for you if you need to keep your configuration.
Sincerely
Bujar
13-Apr-2021 02:57
thanks for your reply Bujar - it's not really an option to factory reset our device so I'll escalate with F5 for a fix. thanks again.
