hmz_360485's avatar
hmz_360485
May 04, 2018
F5 Big-IP HA configuration with SSL certificate
Hi Experts , When we configure the Big-IP fail-over configuration ,Is SSL certificate fail-over between active and standby device ?
  • No. While building trust it's require device trust certificate to communicate each other on secure way(exchange information). But during failover SSL not require.please elobrate some more to understand your requirement.
  • If you are referring to SSL certs you uploaded in support of a service, for SSL offloading as an example, then as long as your active and standby LTMs are in sync the cert will be available on both devices.
