dbaimakov's avatar
dbaimakov
Oct 23, 2023
Solved
Exception for GeoBlocked Country. Without Allow-Listing a specific IP
We are geo-blocking users from China, but some users are trying to ship goods and needs to see access certain guidelines regarding the types of goods that are allowed.
The security policy that governs access to this application also applies to several other applications. I am concerned that allow-listing the specific IP addresses of those users could potentially open up a security loophole.
We are in a bit of pickle and exploring the best way to address this issue without compromising security protocols. Any suggestions would be appriciated.
I tinkered and composed this iRule. I am uncertain about the last part... (ignore private.url as I don't want to post it publcily here)
when CLIENT_ACCEPTED {
    # Initialize a variable to hold the block status
    set blocked_ip 1
    # Check if the request is for the specific full URL and the client is from China
    if { ([HTTP::host] equals "private.url") and
         ([HTTP::uri] equals "/substances-search/Substance?lang=en") and
         ([whereis [IP::client_addr] country] equals "CN") } {
        # Tentatively allow access, pending the ASM check
        set blocked_ip 0
when ASM_REQUEST_DONE {
    # Check if the request is blocked by ASM
    if { [ASM::status] eq "blocked" } {
        # If it's due to geolocation and the specified conditions are met, unblock
        if { [ASM::violation names] contains "VIOLATION_ILLEGAL_GEOLOCATION" and
             $blocked_ip == 0 } {
            ASM::unblock
            log local0. "[ASM::violation_data] unblocked for [IP::client_addr]"
            # For other violations, ensure the request remains blocked
            set blocked_ip 1
when HTTP_RESPONSE {
    # If the block status is true, respond with a 403 Forbidden
    if { $blocked_ip == 1 and
         [ASM::status] eq "blocked" and
         ![ASM::violation names] contains "VIOLATION_SQL_INJECTION" } {
        HTTP::respond 403 content "Access denied" "Content-Type" "text/plain" "Connection" "close"
  • Hi dbaimakov,
    You can use two waf policies and disable the geolocation control in one policy.
  • dbaimakov From my understanding the only way around this would be to create an IP exception list since the IP database is grouped all together in country code CN.
  • Hi dbaimakov,
