AndersNordby's avatar
AndersNordby
Apr 15, 2020
Evaluate access policy with SPNEGO/Kerberos from iRule for certain URL paths only
Hello,
I have a VS with an iRule where I try to use an access policy with Kerberos (AD / SPNEGO integrated Windows) authentication on certain URLs only. It works fine if I apply the access policy on the whole VS, but I want to use it only on some URLs! See iRule code below.
Some things that are OK:
1) ACESS:session exists returns we have a valid session, returned in session_exists variable outputted in response.
Problems I have are a plenty:
2) The ACCESS::policy evaluate always returns deny. Why?
3) I don't get any details about the reason for 2) in Access Policy -> Event Logs. Tried to make a new Event Logs Settings with everything and his uncle turned on byt to no avail.
4) I don't even get a session ID from set session_id [ACCESS::session sid]. Sucks to be me.. Do I have a valid session? What is the session ID? I can see some session IDs in Access Policy -> Event Logs -> Access System Logs -> Built In Reports -> All Messages that correlates with my curl testing. But I can't find any session details for the session ID apart from the session getting created (nothing about the policy evaluation - sigh) in Session Details searching for that session ID.
Any clues?
when CLIENT_ACCEPTED {
  # When we accept a connection, create an Access session and save the session ID.
  set flow_sid [ACCESS::session create -timeout 600 -lifetime 3600]
  set uri [HTTP::uri]
  set req_adlogin 0
  set userprincipalname [string toupper [ACCESS::session data get session.logon.last.username]]
  HTTP::header insert "X-UserName" $userprincipalname
  if { [ACCESS::session exists -sid $flow_sid] } {
    set session_exists true
    set session_exists false
  switch -regexp [HTTP::uri] {
    "^/funky" -
    "^/frozen" -
    "^/yogurt" {
      set req_adlogin 1
  set response_info "adlogin=$req_adlogin uri=$uri session_exists=$session_exists userprincipalname=$userprincipalname"
  if { $req_adlogin equals "0" } {
    HTTP::respond 200 content "Yaddayadda the URL is freee. $response_info"
    pool web_spnegotest_pool
    ACCESS::policy evaluate -sid $flow_sid -profile /Common/spnegotest_access
    switch [ACCESS::policy result -sid $flow_sid] {
      "allow" {
        HTTP::respond 200 content "<html><body>You made it ($flow_sid)! $response_info</body></html>"
      "deny" {
        HTTP::respond 200 content "<html><body>Go away ($flow_sid)! $response_info session_id=$session_id</body></html>"
      default {
        HTTP::respond 200 content "<html><body>Different result than expected - check your configuration. ($flow_sid) $response_info</body></html>"
when CLIENT_CLOSED {
  # To avoid clutter, remove the access session for the flow.
  ACCESS::session remove -sid $flow_sid
