Technical Forum
Enable TLS 1.3 and Disable DH group
SolarJeans
Cirrus
Cirrus
Hello Experts,
I have a task need to enable TLS 1.3 and disable DH group.
To enable TLS 1.3, I can use cipher group to do by this link https://my.f5.com/manage/s/article/K10251520
To disable DH, I can use DEFAULT:!DH
But how to do this together?
1 ACCEPTED SOLUTION
3 REPLIES 3
Paulius
MVP
MVP
@SolarJeans This link should assist you in creating the appropriate custom cipher group.
https://techdocs.f5.com/en-us/bigip-15-0-0/big-ip-ltm-configuring-custom-cipher-string-for-ssl-negot...
Hello,
Yes, I try to create custom cipher rule and custom cipher group and issue fixed. Thanks a lot.
Samir
MVP
MVP
You can try something like this to enable tls1.3 and disable DHE
DEFAULT:TLSV1_3:!DHE
