F5user13_114603's avatar
Nov 22, 2017
Solved
ECV health monitor for Microsoft Azure RMS
Trying to create an ECV for Azure Rights management server.
https://rms.abc.com/_wmcs/certification/certification.asmx
Expected reply: CertificationWebService
Username & password are provided by application owner.
Configured below on https health monitor
Send string: GET/_wmcs/certification/certification.asmx HTTP/1.1\r\nHost:rms.abc.com Receive String: CertificationWebService
Username: testusr@abc.com Password: *******
The pool members are marked down.
doing a curl -k gives below error
HTTP Error 401.2 - Unauthorized You are not authorized to view this page due to invalid authentication headers.
Most likely causes:
  • No authentication protocol (including anonymous) is selected in IIS.
  • Only integrated authentication is enabled, and a client browser was used that does not support integrated authentication.
  • Integrated authentication is enabled and the request was sent through a proxy that changed the authentication headers before they reach the Web server.
  • The Web server is not configured for anonymous access and a required authorization header was not received.
  • The "configuration/system.webServer/authorization" configuration section may be explicitly denying the user access.
Things you can try:
  • Verify the authentication setting for the resource and then try requesting the resource using that authentication method.
  • Verify that the client browser supports Integrated authentication.
  • Verify that the request is not going through a proxy when Integrated authentication is used.
  • Verify that the user is not explicitly denied access in the "configuration/system.webServer/authorization" configuration section.
  • Create a tracing rule to track failed requests for this HTTP status code. For more information about creating a tracing rule for failed requests, click here.
Detailed Error Information:
Module IIS Web Core
Notification AuthenticateRequest
Handler WebServiceHandlerFactory-ISAPI-4.0-64
Error Code 0x80070005
  • Got the answer:
    Send string: GET /_wmcs/certification/certification.asmx HTTP/1.1\r\nHost: xyx.abc.com\r\nConnection: Close\r\n\r\n
    Receive string: 401 Unauthorized
    timers: 10/31
  • Got the answer:
    timers: 10/31
