Dual NIC Deployment
Hi All,
I have spinned up 2 F5 VM's via Azure ARM template. Requirement is for Dual NIC same has been visible on the VM's however on the actual F5 VM interfaces showing as single NIC as 1.1. Have any one deployed dual NIC F5 VMs via Azure template please let me how do I get to see 2 interfaces in F5 VM itself.
0 REPLIES 0
