25-Jul-2018 10:13
Is there a cli command by which we can display the hostname of the f5 Device using the cli?
25-Jul-2018 10:35
In F5 unix shell you can print hostname name by typing command hostname
Python SDK
>>> settings = bigip.sys.global_settings.load()
>>> print settings.hostname
LAB1.mydomain.com
OR
Alternatively you can refer this
set hostname [tmsh::get_config /sys global-settings hostname]
puts [tmsh::get_field_value [lindex $hostname 0] hostname]
25-Jul-2018
16:50
- last edited on
02-Jun-2023
08:37
by
JimmyPackets
tmsh
tmsh list sys global-settings hostname
iControl REST
curl -sku admin: https:///mgmt/tm/sys/global-settings?\$select=hostname
20-Nov-2018
19:59
- last edited on
21-Nov-2022
21:41
by
JimmyPackets
I wasn't able to get the code from f5_rock to work (it's most likely my fault) but I did get the hostname with the code below. It's a little verbose because I had to run the tmsh command to show the settings and then I used .lstrip and .strip to clean the data up. Happy coding!
from f5.bigip import ManagementRoot
mgmt = ManagementRoot("your_f5_ip_address", 'username', 'password')
x = mgmt.tm.util.bash.exec_cmd('run', utilCmdArgs='-c "tmsh list sys global-settings hostname | grep "hostname""')
hostname = str(x.commandResult)
hostname = hostname.strip().lstrip('hostname').strip()
print(hostname)
