08-Jan-2021 04:36
Team,
I have tried disabling the weak ciphers using the Cipher.
Cipher Code : ECDHE+SHA256:HIGH:!SSLv3:!RSA:!RC4:!EXP:!LOW:!ADH:!DHE:!DES:!3DES:!TLSv1:!TLSv1_1:TLSv1_2
But Still, I can see few weak Ciphers in Ssllabs.com :
Cipher Suites# TLS 1.2 (suites in server-preferred order)
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (0xc027) ECDH secp384r1 (eq. 7680 bits RSA) FS WEAK 128
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (0xc028) ECDH secp384r1 (eq. 7680 bits RSA) FS WEAK 256
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (0xc014) ECDH secp384r1 (eq. 7680 bits RSA) FS WEAK 256
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (0xc013) ECDH secp384r1 (eq. 7680 bits RSA) FS WEAK 128
08-Jan-2021
05:16
- last edited on
22-Nov-2022
07:47
by
JimmyPackets
Hi Prasad4u,
Try to add !AES on you Cipher Code :
ECDHE+SHA256:HIGH:!SSLv3:!RSA:!RC4:!EXP:!LOW:!ADH:!DHE:!DES:!3DES:!TLSv1:!TLSv1_1:TLSv1_2:!AES
Regards
