F5 https monitor receive string
Hello,
I am testing an HTTPS monitor on BIG-IP 17.1.2.
The server endpoint returns:
HTTP/1.1 200 OK when the service is healthy
HTTP/1.1 503 Service Unavailable when the service is unhealthy
This behavior has been confirmed from the F5 using:
curl
In the HTTPS monitor, I tried the following Receive Strings:
-HTTP/1.1 200
-200 OK
- HTTP 200
but the monitor stays DOWN.
If I use:
-ok||200
the monitor goes UP, however it also remains UP when the endpoint returns HTTP 503.
My question is:
How can I configure a standard HTTPS monitor so that it is UP only when the endpoint returns HTTP 200 and DOWN when it returns HTTP 503?
Thank you.
HI antesmol​ Can you share the complete curl o/p please?
- Jonathancert
Cirrus
Give this try for String config on a Monitor. Other option i can think of is using an iRule
Send String: GET /your-endpoint HTTP/1.1\r\nHost: ://yourdomain.com\r\nConnection: Close\r\n\r\n
Receive String: HTTP/1.1 200 OK
send and receive string config uses regular expression syntax, which "." is also special character
https://my.f5.com/manage/s/article/K5917
