unavailable's avatar
unavailable
Feb 23, 2023
Custom dashboard "behavioral dos"
Hello everyone,
I need to create a custom dashboard that allow to have informaton about "behavioral dos" .
At the moment it is possible to do it only by selecting dashboard from F5 but, if I wanted to create a custom dashboard to include behavioral dos, it is not possible to do it because the system does not allow me to select widget associated to it.
Someone could help me to do it ?
F5 version is 16,1,3,3
  • Hi Leslie_Hubertus,
    many thanks for your support.
       I will wait if someone help me to do it.
    • AubreyKingF5's avatar
      AubreyKingF5
      Icon for Moderator rankModerator
      Typically, any customizations like this is done on a SIEM. That is my recommendation, personally. Do you have a SIEM or ELK?
  • Hi AubreyKingF5,
    many thanks for your reply.
    I don't have SIEM or ELK.
    Regards,
      AubreyKingF5
      This might be a request to your system engineer, then, unfortunately. If I recall correctly, they need a case from support to initiate a product enhancement.
