Michel_van_der_
Nov 14, 2003CPU utilization and kernel memory utilization
Can I get my hands on those using iControl? This is for a BigIP running
4.2 at the moment. Hope to go to 4.5 RSN.
The information in ITCMLocalLB.Global.get_statistics
(GLOBAL_STATISTIC_MEM_POOL_TOTAL and GLOBAL_STATISTIC_MEM_POOL_USED ) is apparently not
quite the later.
Thanks.
- What specifically are you looking to infer from the CPU and kernel memory utilization? The mem pool total and used metrics relate to the amount of memory the core processing subsystem allocates and uses from the system. To a point you can infer red-lining from these metrics as they directly relate to the amount of configuration and connection information the processing components have free. When the used metric reaches the total then that would imply the box is reaching capacity.
In 4.2, as far as my memory serves me, these are the only 2 memory metrics available.
-Joe - Michel_van_der_
I'm mostly interested in this data for capacity planning purposes. When
should I start thinking about adding memory, should I perhaps move
some load balancing service from one set to another, those types of
things.
The issue that brought this to my attention was that I noticed one of
our F5 boxes rebooted spontaneously the other day. Turns out it was
because the kernel memory consumption reached 95%. However the
data from the statistics I got through iControl showed only about 75%
utilization (which is what 'bigpipe ms' showed me as well).
Looking through your various tech articles (e.g. SOL192), it is not clear
to me, how the output from 'bigpipe ms' (and in extension the data
gathered from iControl), relates to the kernel message we were seeing,
i.e. there seems to be a significant discrepency.
Also, it would be nice to have a more extensive description of all of the
statistics that are available.
Also, what about CPU utilization? Is that available though iControl? My
boxes don't appear even slightly stressed, but I'd like to track it to make
sure.
Thanks, Michel - I like to refer to this issue as "red-lining". For the next generation of products we are working on building more of these types of features into the product. I don't have the information when these features will be available but suffice it to say it will be fairly soon as this is not a uncommon reuqest. On the 4.x platforms there were platform architectural limitations stopping us from accurately determining red-line situations.
As for CPU metrics, this is something we are also adding in future versions but is not available on 4.2.
I try to answer as many product related questions as possible here but when it goes too far beyond the development of iControl applications you will get better support and more reliable answers by contacting F5 technical support directly. Their specialty is with questions like this.
F5 Technical Support
Email: support@f5.com
Phone: 206-272-6888
Web: http://www.f5.com/support/
AskF5: http://tech.f5.com/
