configuration of f5 load balancer in BIG IP version 14.1.2 guide
JMutie
Hello DevCentral,
Anyone with documentation on F5 loadbalancer configuration for version 14 please share.
Getting error.
telnet: Unable to connect to remote host: Connection refused
root@MSA-DNS01 # telnet 10.15.13.133 443
Kind Regards,
Jackson
5 REPLIES 5
Shaun_Simmons
F5 Employee
F5 Employee
Could you elaborate a bit more? Your example could have multiple replies, not knowing how you have the BIGIP and network configured.
Can you ping 10.15.13.133? --Which is a VIP IP? Also, are you able to ping the pool members of the VIP from the BIGIP?
BIG-IP LTM-DNS operations guide
https://support.f5.com/csp/article/K70671013
JMutie
Yes. I can ping from LAN the Virtual server IP. It seems the AFM needs to be configured to allow access. AFM is enabled. The device is in firewall mode,so it acts like a default deny FW. You;ll have to create an AFM policy/rule set that will allow 443 on that address. Please share guide on AFM policy configuration.
Lidev
MVP
MVP
Great Link!
NAG
This might help you to get to know more on AFM
https://support.f5.com/csp/article/K38201755
