26-Aug-2020
11:17
- last edited on
22-Nov-2022
15:12
by
JimmyPackets
I'm struggling to get a conditional policy based on URI to work properly. I'm trying to set X-Frame-Options based on paths, such that the header is more relaxed on specific paths, but more strict on anything else. The below code results in ALLOWALL for pretty much everything. I'm fairly certain the application is sending ALLOWALL for everything. I'm just trying to enforce defaults at the LTM, permiting conditional.
"X-Frame-Options header SAMEORIGIN" {
actions {
0 {
http-header
response
replace
name X-Frame-Options
value SAMEORIGIN
conditions {
0 {
http-uri
path
not
starts-with
values { /path-a/ /path-b/subpath/ /path-c/
1 {
http-header
response
not
contains
values { SAMEORIGIN }
ordinal 3
"X-Frame-Options header ALLOWALL" {
actions {
0 {
http-header
response
replace
value ALLOWALL
conditions {
0 {
http-uri
path
starts-with
values { /path-a/ /path-b/subpath/ /path-c/ }
1 {
http-header
response
not
contains
values { ALLOWALL }
ordinal 2
27-Aug-2020 07:30
Kevin, do you have a OneConnect profile attached to the VS? Also see K15097 to see if this looks to explain what you are seeing, even though this references Pools and not headers.
Hope this helps
N
