Technical Forum
Custom Alert Banner
Can SSL Orchestrator do daisy chaining to a Proxy first then to an ICAP server?
Wasfi_Bounni
Cirrocumulus
Cirrocumulus
Hi;
Let's say I want to decrypt on the Orchestrator, then send the clear text traffic to a Proxy device, then when it comes back from the Proxy, have the Orchestrator send it over ICAP to an ICAP server. I guess my question is: can the Proxy and the ICAP server be in the same daisy chain?
Kindly
Wasfi
1 ACCEPTED SOLUTION
Andrew-F5
F5 Employee
F5 Employee
Yes they can. This is part of the service chain and the order of each service (ICAP, Proxy, etc) can be defined as well.
Lab 1.7: Service Chain List
1 REPLY 1
Andrew-F5
F5 Employee
F5 Employee
