13-Jul-2020 05:04
Can i DO direct Upgrade my BIG IP LTM from v 13.1.0.2 (Build 0.0.6) version to 15.1.0.4 or Do i need to go for any other Base Versions
Can some one suggest me
13-Jul-2020 06:01
According to this site from f5, it is possible to upgrade from 13.x to 15.x
https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/product/relnote-bigip-15-1-0.html
Here ist my message from the LB:
"The configuration has not yet loaded. If this message persists, it may indicate a configuration problem."
