markovichi's avatar
markovichi
Jun 15, 2023
Body Size Limit F5 AWS WAF managed rule
I am subscribing the F5-OWASP_Managed then attach it to my AWS WAF. I am seeking a solution to block OWASP attack that happen on body. my question is: does the F5 managed rule group follows the AWS body size inspection limit (16 KB), or it has different limit? thank you
  • Hi markovichi ,
    The F5 managed rule group does not add or conttrol any size inspection limit. Such limits are attributes of AWS's Web ACL. There are different limits enforced by AWS, but whchever you have shoudl remain the same when using F5 manged rule groups.
    Joel
  • markovichi - If your post was solved it would be helpful to the community to select *Accept As Solution*.
    This helps future readers find answers more quickly and confirms the efforts of those who helped.
    Thanks for being part of our community.
    Lief
