NGINX Plus Request body Rate Limit with the NJS module and javascript
Nginx by default can't do a rate limiting based on the Request Body but the javascript NJS module this is no longer an issue and I will share how 😀
The nginx njs module allows javascript to process the code or as they call it on the backend nodejs. The module is dynamic for Nginx Plus https://docs.nginx.com/nginx/admin-guide/dynamic-modules/dynamic-modules/ while for the community nginx it needs to be compiled.
The code and nginx configuration are also present at:
https://github.com/Nikoolayy1/nginx_njs_request_body_limit/tree/main
I have used the example rate limiter from https://github.com/nginx/njs-examples and https://clouddocs.f5.com/training/community/nginx/html/class3/class3.html and modified rate limit example to be based on the request body.
It works as expected. The "r.internalRedirect('@app-backend');" internal redirect is needed as nginx by default does not populate or save the request body and this is why the request needs to pass 2 times in nginx proxy for the body variable to be properly populated!
The nginx plus rootless container is a great option for F5 XC RE where root containers are not accepted and for Nginx on XC RE I have made another article at F5 XC vk8s open source nginx deployment on RE | DevCentral
NJS "main" file code:
const defaultResponse = "0";
const user = 'username';
const pass = 'username';
function ratelimit(r) {
      switch (r.method) {
      case 'POST':
         var body  = r.requestText;
          r.log(`body: ${body}`);
     if (r.headersIn['Content-Type'] != 'application/x-www-form-urlencoded' || !body.length)
              return;
           var result_user = body.includes(user);
           var result_pass = body.includes(pass);
                      if (!result_user) {
                             return;
    const zone = r.variables['rl_zone_name'];
    const kv = zone && ngx.shared && ngx.shared[zone];
    if (!kv) {
        r.log(`ratelimit: ${zone} js_shared_dict_zone not found`);
        return;
    const key = r.variables['rl_key'] || r.variables['remote_addr'];
    const window = Number(r.variables['rl_windows_ms']) || 60000;
    const limit = Number(r.variables['rl_limit']) || 10;
    const now = Date.now();
    let requestData = kv.get(key);
    if (requestData === undefined || requestData.length === 0) {
        requestData = { timestamp: now, count: 1 }
        kv.set(key, JSON.stringify(requestData));
        return;
    try {
        requestData = JSON.parse(requestData);
    } catch (e) {
        return;
    if (!requestData) {
        return;
    if (now - requestData.timestamp >= window) {
        requestData.timestamp = now;
        requestData.count = 1;
        requestData.count++;
    const elapsed = now - requestData.timestamp;
    r.log(`limit: ${limit} window: ${window} elapsed: ${elapsed}  count: ${requestData.count} timestamp: ${requestData.timestamp}`)
    let retryAfter = 0;
    if (requestData.count > limit) {
        retryAfter = 1;
   if (retryAfter) {
            r.return(401, "Unauthorized\n");
           return;
      default:
           return;
export default {sub, header, ratelimit, parseRequestBody, log};
Nginx nginx.conf file:
 server {
    listen       80 default_server;
    server_name  localhost;
   access_log  /var/log/nginx/host.access.log  main;
   js_var $rl_zone_name kv;          # shared dict zone name; requred variable
    js_var $rl_windows_ms 30000;      # optional window in miliseconds; default 1 minute window if not set
    js_var $rl_limit 3;              # optional limit for the window; default 10 requests if not set
    js_var $rl_key $remote_addr;      # rate limit key; default remote_addr if not set
    js_set $rl_result main.ratelimit; # call ratelimit function that returns retry-after value if limit is exceeded
    root /var/www/html;
    index  index.html;
    include       /etc/nginx/mime.types;
error_log  /var/log/nginx/host.error_log  debug;
if ($target) {
    return 401;
    location / {
       js_content main.ratelimit;
     location @app-backend {
          internal;
          proxy_pass http://backend;
location /backend {
   internal;
   proxy_set_header Host httpforever.com;
   proxy_pass http://backend/;
Summary:
There is another example how to populate the internal request body variable using that is needed by the njs module using the " mirror " option, shown at https://www.f5.com/company/blog/nginx/deploying-nginx-plus-as-an-api-gateway-part-2-protecting-backend-services  but it did not work for me, so I used the " internal " option with "r.internalRedirect(uri)" https://nginx.org/en/docs/njs/reference.html
Nginx njs feature r.subrequest can be used to populate response headers and body but mainly it is for logging and not for rate limiting and I think making a real http subrequest using javascript is not optimal and will not scale well, so I will not recommend this option as rate limiters are best left to be request based. Also I saw strange bug that the subrequest changes the content type header of the response and I had use "js_header_filter" to again change the response header.Nginx App Protect has the BD process from F5 BIG-IP AWAF/ASM that has DOS protections that can monitor the Server's response latency dynamically and make auto thresholds!
Updated Aug 06, 2025
Version 2.0
