26-Feb-2020 01:54
Hi There:
my BIGIQ version is 7.0.1
[INFO][26 Feb 2020 15:44:50 CST][/cm/cloud/tasks/aws/initial-buildout/cb251528-f3cc-4510-aacd-e483c1ae06bf/worker InitialBuildOutTaskWorker] Validated initial build out task parameters for ssg awssg.
[INFO][26 Feb 2020 15:44:50 CST][/cm/cloud/tasks/aws/initial-buildout/cb251528-f3cc-4510-aacd-e483c1ae06bf/worker InitialBuildOutTaskWorker] Polling: /mgmt/cm/cloud/orchestrator/aws/tasks/deploy-auto-scale/f00a37c6-03cf-4884-bd53-9e4a786a2f87
[WARN][26 Feb 2020 15:46:51 CST][/cm/cloud/tasks/aws/initial-buildout/cb251528-f3cc-4510-aacd-e483c1ae06bf/worker InitialBuildOutTaskWorker] Failed to trigger the flask task: java.lang.IllegalStateException: Applying Auto Scale Cloud Formation Template failed due to ClientError: An error occurred (500) when calling the CreateStack operation (reached max retries: 4): Internal Server Error
at com.f5.rest.workers.cloud.task.FlaskUtils$2.completed(FlaskUtils.java:148)
at com.f5.rest.workers.cloud.task.FlaskUtils$2.completed(FlaskUtils.java:123)
at com.f5.rest.common.RestOperation.complete(RestOperation.java:2713)
at com.f5.rest.common.ApacheAsyncRequestSender.lambda$completeRequestOnNonBlockingPool$5(ApacheAsyncRequestSender.java:374)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
[ERROR][26 Feb 2020 15:46:51 CST][/cm/cloud/tasks/aws/initial-buildout/cb251528-f3cc-4510-aacd-e483c1ae06bf/worker InitialBuildOutTaskWorker] Failed to trigger the flask task: java.lang.IllegalStateException: Applying Auto Scale Cloud Formation Template failed due to ClientE
2020-02-26 03:44:52 PM 2023 DEPLOY_STACK: Detected BYOL license type. Setting up credentials in a s3 bucket for awssg
2020-02-26 03:44:53 PM 2023 Starting new HTTPS connection (1): s3.cn-northwest-1.amazonaws.com.cn
2020-02-26 03:44:53 PM 2023 Starting new HTTPS connection (2): s3.cn-northwest-1.amazonaws.com.cn
2020-02-26 03:44:53 PM 2023 DEPLOY_STACK: Applying the Auto Scale Cloud Formation Template for awssg
2020-02-26 03:44:53 PM 2023 Applying Auto Scale CFT
2020-02-26 03:44:54 PM 2023 start task = TASK: Launch ansible CFT
2020-02-26 03:46:49 PM 2023 Ansible callback on failed...
