08-Apr-2020 07:17
I'm using the requests module (not the f5-sdk library) with Python to add LTM objects and am having an issue with POST. The following code works:
def node():
body = """
"name": "test-node1",
"address": "1.1.1.40"
headers = {"Content-Type": "application/json"}
uri = f"https://ltmlab/mgmt/tm/ltm/node"
response = requests.post(
uri, auth=("admin", PASSWORD), headers=headers, data=body, verify=False
print('status code:', response.status_code)
However, the following code produces a 400 bad request:
def node():
body = \
I suppose I could continue to use the function that works, however does not seem very 'Pythonic' and also presents messy code if I have multiple objects of the same type to configure. I've also tried iterating over the following json file, but I still receive the same 400 bad request:
with open('examaple.json') as f:
json_dict = json.load(f)
# json file contents
"nodes": [
"name": "node1",
"name": "node2",
"address": "2.2.2.40"
Any help would be appreciated. Thanks in advance.
Solved! Go to Solution.
08-Apr-2020 13:45
Hello Ken.
I recommend you to use the F5-SDK. You can install the module using pip:
REF - https://f5-sdk.readthedocs.io/en/latest/
To create a node is as simple as this:
from f5.bigip import ManagementRoot
session = ManagementRoot("F5_mgmt_IP","username","password",token=True)
node = session.tm.ltm.nodes.node.create(name='node_10.1.1.1', address='10.1.1.1', description='123abc', partition='Common')
KR,
Dario.
08-Apr-2020 13:45
Hello Ken.
KR,
Dario.
08-Apr-2020 19:10
Thank you Dario. I agree with what you're saying, it just seems that REST using the requests module seems to match up a little better with the TMSH command structure than the sdk. Taking your advice, the following code worked well. Thank you for your input.
from getpass import getpass
PASSWORD = getpass()
session = ManagementRoot("lab-ltm", "admin", PASSWORD, token=True)
def node():
nodes = [
{"name": "node-test1", "address": "1.1.1.40"},
{"name": "node-test2", "address": "2.2.2.80"},
for node in nodes:
nodes = session.tm.ltm.nodes.node.create(
name=node["name"], address=node["address"], partition="Common"
pool()
def pool():
pool = session.tm.ltm.pools.pool.create(name="pool-test", monitor="tcp")
pool_load = session.tm.ltm.pools.pool.load(name="pool-test")
nodes = ["node-test1:80", "node-test2:80"]
for node in nodes:
member_load = pool_load.members_s.members.create(name=node, partition="Common")
virtual()
def virtual():
params = {
"name": "vs-test-virtual",
"destination": "200.200.200.200:8080",
"mask": "255.255.255.255",
"ipProtocol": "tcp",
"pool": "test_pool",
"profiles": [
"http",
"f5-tcp-wan",
{"name": "clientssl", "context": "clientside"},
"partition": "Common",
"sourceAddressTranslation": {"type": "automap"},
virtual = session.tm.ltm.virtuals.virtual.create(**params)
if __name__ == "__main__":
node()
