Ryan_34424's avatar
Ryan_34424
Dec 12, 2018
BIG-IQ :: Add Hard Disk to VE
Ok, my Google-fu is lacking today. More coffee needed perhaps.
But for the life of me, I cannot figure out how to add another disk (virtual hard drive) to my BIG-IQ VE. I don't want to expand the current disk... which is what I am finding all of the articles pertain to (and which I already know how to do). My desire is to add another HD (via HD2) to the VE.
Any ideas on how to accomplish this?
root@(big-iq)(cfg-sync Standalone)(Active)(/Common)(tmos) show sys hardware
Sys::Hardware
Chassis Information
  Chassis Name
  Chassis Type
  Maximum MAC Count  1
  Registration Key   -
Hardware Version Information
  Name        HD1
  Type        physical-disk
  Model       Virtual disk
  Parameters  --                --
              Manufacturer      VMware
              SerialNumber      VMware-sda
              Size              95.00G
              Firmware Version  1.0
              Media Type        HDD
  Name        HD2
  Type        physical-disk
  Model       Virtual disk
  Parameters  --                --
              Manufacturer      VMware
              SerialNumber      VMware-sdb
              Size              95.00G
              Media Type        HDD
It seems that the VE can see the drive... but I can't install to it:
  root@(big-iq)(cfg-sync Standalone)(Active)(/Common)(tmos) install sys software image BIG-IQ-6.1.0-0.0.1224.iso create-volume volume HD2.1
  root@(big-iq)(cfg-sync Standalone)(Active)(/Common)(tmos) show sys software status
  Sys::Software Status
  Volume  Product  Version     Build  Active                                   Status
  HD1.1    BIG-IQ    6.0.0  0.0.1674     yes                                 complete
  HD2.1    BIG-IQ    6.1.0  0.0.1224      no  failed (Can't find requested disk HD2.)
I assume I am missing a step here.
Thanks in advance! -R
  • From Support:
    I have an update for this. For an installation, you have to extend the existing volume. The additional disk is usable for data storage, but not for installation.
    list /sys disk all-properties
    sys disk logical-disk HD1 {
        mode mixed <------- this can be used to install
        size 97280
        vg-free 42160
        vg-in-use 53868
        vg-reserved 0
    sys disk logical-disk HD2 {
        mode none <---------- This needs to be 'mixed'
        size 97280
        vg-free 0
        vg-in-use 0
        vg-reserved 19456
    Basically HD2 exists only for some objects (datastore) but is not a valid OS install location.
    https://support.f5.com/csp/article/K16103 - Extending disk space on BIG-IQ Virtual Edition
