starboy's avatar
starboy
Icon for Cirrus rankCirrus
Feb 17, 2020
Solved
BIG-IP placement
Hi All
I want DC to DR availability and i have two BIG-IP DNS one for DC and the other for DR so i want to know where to place the BIG-IP DNS i have no clue? before my Firewall or WAN edge Router or behind my WAN edge/ Firewall please any suggestion ?
Regards
  • Hello,
    You would want to place that behind your WAN edge router and firewall. You are only going to need to allow traffic through to the listener IP on the BigIP DNS from external and internally you would need a heartbeat network between the two data centers for config sync.
    I hope this helps!
  • Hello,
    I hope this helps!
