Technical Forum
BIG-IP i7600-D High CPU - Control Plane
Quynh_Nguyen_Du
Altocumulus
Altocumulus
Dear all,
I have issues with my BIG-IP i7600-D. Non traffic on box but control plane with high cpu as pictures below.
Box running version BIG-IP 15.1.0.5 Build 0.0.8 Point Release 5 with license AWAF . So anyone can help me explain or fix this issues.
Thank you so much and have a nice day!
2 REPLIES 2
Ivan_Chernenkii
F5 Employee
F5 Employee
Hello Quynh,
As I see, you have some unclear "Degraded:Disconnected" status on you BIG-IP. What does it mean?
If this BIG-IP in CMI (HA group), then most probably you have some problem with configuration sync.
Control plane is not related to traffic - it can be high because of some configuration issues.
Do you have any errors in /var/log/asm, /var/log/ltm, /var/log/ts/asm_config_server.log, /var/log/nsyncd.log?
Thanks, Ivan
Hi Ivan,
Thank for your reply.
I know control plane not process traffic.
Degraded:Disconnected" status on you BIG-IP because i have use monitoring interface and interface have status down ( i just want isolate traffic )
I have factory the bigip to default, clean software image and reinstall. ​Now cpu control plane is ok
Thanks!​
