Technical Forum
big ip edge client not connecting windows 10
F5_LB_Eng
Hi ,
i am trying to connect the the big ip edge client in windows 10 . using bip ip edge client am not able to connect.
same i am trying to access using browser its works fine.
in edge client i am getting the below error message
1. SSL certitifate contains errors
2. cannot reach server.change any way?
some one help me on fixing the issue.
2 REPLIES 2
Macarthur43
Did you find the COLA Social Security solution?
No solution so far...waiting
