AS3 referencing objects across applications
Hi, I'm new to using AS3 for configuration.
I'm trying to do the following with my decloration:
"declaration": { "class": "ADC", "schemaVersion": "3.43.0", "id": "id", "label": "WebApp", "myPart": { "class": "Tenant", "Shared": { "class": "Application", "template":"shared", "myEnv_vs": { "class": "Service_HTTP", "virtualAddresses": ["10.1.2.2"], "virtualPort": 80, "pool": /-- Refer to app2_pool --/ } }, "APP1": { "class": "Application", "app1_pool": { "class": "Pool", "members": [ { "servicePort": 8080, "serverAddresses": [ "10.2.2.3" ] } ] } }, "APP2": { "class": "Application", "app2_pool": { "class": "Pool", "members": [ { "servicePort": 8080, "serverAddresses": [ "10.2.2.4" ] } ] } } } |
I've bolded the line that I have questions about. Is referring to the APP2 pool even possible from the Shared object?
I've tried several different means to achieve this and got errors stating:
"pool": "/myPart/APP2/app2_pool" --> Can only refer to things in /myPart/Shared/ or /Common/Shared/
"pool": "app2_pool" --> does not exist
"pool": "APP2/app2_pool" --> does not exist
Am I barking up the wrong tree? Does this make sense?
Hi Leslie_Hubertus,
I talked with some contacts at F5 and apparently what I was attempting to complete is not possible.
As much as I would like to be able to refer to other apps in a partition I understand why it behaves like that.
