25-Dec-2020 07:29
Are there any examples of the AS3 for APM that the new release of AS3 has?
I am interested in modifying paths for apis deployed so i can tie and automate with api releases from the application backend side.
thanks!!
A
29-Dec-2020 14:13
Hello Drairios.
These are the only examples I've found for AS3 with APM.
https://clouddocs.f5.com/products/extensions/f5-appsvcs-extension/latest/declarations/access-related.html
APM policy support was release just a few months ago
https://clouddocs.f5.com/products/extensions/f5-appsvcs-extension/latest/refguide/revision-history.html
Regards,
Dario.
30-Dec-2020 04:20
thx so much those docs do not give the details. Is there a json schema for APM so I can write it?
the problem to solve is the constant updated I need to do to API protect Access configurations due to the app developers adding and/or changing bindpoints for the apis. So I want to allow them to publish somehow the paths to the Access config. Any other suggested way to allow thing like path change updates only you may suggest?
