Technical Forum
AS3 422 after upgrade to 3.41.0
Norbert_Phillip
We recently upgraded bigiq to 8.3.0 and then downgraded AS3 to 3.41.0. Our AS3 declarations are now failing with 422 telling us that our server tls profile is expecting an absolute path,  and that serverTLS may be applied to a Service that doesn't support it. The template is generic and the cloass is ServiceHTTPS.
Any suggestions or ideas on how to fix?
1 REPLY 1
Norbert_Phillip
If I use an absolute path I then get the error:
{"message":"TypeError: config.properties.api-anonymous.trim is not a function","level":"error"}
