Technical Forum
Archive error in BIGIP
THE_BLUE
Cirrus
Cirrus
I'm receiving below error while trying to create new archive in bigip. How to solve it ?
No space left on device
/var/local/ucs/backup.ucs: Error renaming package
WARNING:There are error(s) during saving.
        Not everything was saved.
        Be very careful when using this saved file!
Error creating package
Error during config save.
Unexpected Error: UCS saving process failed.
3 REPLIES 3
Samir
MVP
MVP
Looks like there is no space in /var/local/ucs/ thats the reason getting error.
# df -h ==> check the space in /var directory
Suggest to remove/move old UCS to remote device or you can store in "/shared/image/"
Example:
tmsh save sys ucs /shared/ucs/filename.ucs
THE_BLUE
Cirrus
Cirrus
Hi Samir,
i have tou run tmsh save sys ucs /shared/ucs/filename.ucs after create the archive from gui? or befoer?
Samir
MVP
MVP
Run this in tmsh cli. gui by default store in /var/local/ folder.​
