- iaineNacreous
How are you seeing this...? If you go to Manage Sessions in the GUI, are you seeing sessions remain active past the Expiration time?
- Antish_293579Nimbostratus
Actually due to this "timeoutgent.php" uri, session gets extended by 3 mins.i mean session expiration gets increased by every HTTP request.Not sure if this is the reason why we never see session ended.
- Stan_WardAltocumulus
Is timeoutagent.php inserted by APM? It sounds like a keepalive that keeps resetting the inactivity timer.
timeoutagent.php comes in F12 as per inactivity time out in Access policy profile setting like 120 secs
screenshot would help probably
. so i have set Inactivity timeout to 300 secs, at same interval i see this timeoutagent.php. But session does not end, ideally it should. what is happening is i see the session expiration increasing by 3 mins every time this HTTP request comes , checking under manage sessions option.But why is that so?
this is during the logon screen right? so you are working on the logon screen timer?
this is not on login screen. this is on home page of my application.
- Yann_Desmarest_Nacreous
The timeoutagent page is called by a javascript inserted by APM. Its goal is to detect when your session reach the timeout to trigger another javascript displaying a dialog window explaining the session has expired or to trigger a redirect to the ending page
it should not affect the timeout counters by itself
whatever you mentioned is not happening actually. This is the issue. Actually due to this "timeoutgent.php" uri, session gets extended by 3 mins every time.
