mika's avatar
mika
Icon for Cirrus rankCirrus
Oct 09, 2020
Active and passive node
Hi guys,
Lets say i have Node 1 and Node 2.
And i do want f5 ltm to monitor both but at any given time we want only one server to be active and other to be passive.
Can we make Node1 as primary Node and then if primary is down make the second Node2 should be active node.
Can we achieve this via configuration or do I need to write Irules.
If so can some one share how to implement or configure this.
Best regards,
Malika
  • Hello Mika.
    You can use priorities to set that. An example below:
    https://smartvision.solutions/?q=node/8
    Regards,
    Dario.
  • Hello Mika,
    You can look if Priority Group Activation will resolve your requirement
