Technical Forum
Custom Alert Banner
Accessing the web interface on Hyper-V (trial edition)
marco_shaw
I have 16.1 which I installed in Windows 10 Pro Hyper-V. I can use Putty from the Windows 10 host to SSH to the management IP, so that's good.
However, I cannot hit that IP with a web browser. I did a netstat -an, and a few other commands I found online and nothing is listening on port 443.
Is there a command to enable the web GUI?
(I'm using DHCP, might that be a problem for me to just horse around with LTE?)
1 REPLY 1
marco_shaw
https://clouddocs.f5.com/cloud/public/v1/hyperv/hyperv_setup.html
Which states:
When BIG-IP VE first boots, it determines the number of active NICs. If BIG-IP VE detects one NIC, then:
The port for the Configuration utility is moved from 443 to 8443.
Now to try to login...
