Jim_Couch_16225's avatar
Jim_Couch_16225
Nov 20, 2018
13.1.1 upgrade on Lab F5
I am preparing to upgrade our F5s and the recommended version is 13.1.1 from 12.1.1.1.0.196. I generally upgrade my test set, which has a lab license, first so that I know what I might run into. I imported 13.1.1 and checked with the MD5 but when I install into Vol 2, I get a Failed message. I looked in the log and I am getting:
info: Applying UCS /var/tmp/lsD65KX1dS.ucs to disk sda, location 2 (/mnt/tm_install/12238.l4FaeM). info: >++++ result: info: cp: writing `/mnt/tm_install/12238.l4FaeM/var/local/ucs/config.ucs': No space left on device
So I am curious if anyone has had issues installing 13.1.1 on a LAB licensed VE. I also tried 13.0.0.
Jim
  • Hi Jim.
    Which steps do you follow to do the upgrade?
    I typically do the following:
    1. Create archive before any config changes.
    2. Disable all syncs, and auto failover, free up disk space.I do not sync from this point onwards until all servers are updated and confirmed working.
    3. Verify config on all partitions are healthy.
    4. Record connection numbers for reference point, no need if you have AVR.
    5. Re-license.
    6. Check md5 of iso.
    7. Run install to a new partition.
    8. Do step 5, and confirm traffic flows without any drops or problems. Compare connection numbers
    9. Enable syncs and failover methods.
    10. Do step 1.
    11. Smile.
    12. Done.
  • "s/config.ucs': No space left on device"
    I think Pete is right. You're disk volume seems to be full, so your Device cannot write the size of data on your drive. To check have a look at "System -> Disk Management" to check if there's enough space.
  • Karl: My steps are nearly identical to yours except that I dont worry that much on my test set because most of the time there are no configs or connections on it. The other thing is that I am not sure how to free up disk space. I'm not sure what is okay to free up and what is not. I have removed all the old images and hotfix's.
    Pete and Hank: I agree. It is a space issue but I have cleaned off the old ISOs and hotfix's and I still get the error. I'm wondering if a lab license is able to host a 13.x image? Is there a trick to re-partitioning so the 13.x image will load?
  • Once you cleanup the image files and hotfixes, perform mcpd reload and then rebot the device.
    please verify /var/local/ucs folder and see any old UCS files are available, if yes remove them.
    Please give output of df -kh.
    • Jim_Couch_16225's avatar
      Jim_Couch_16225
      There is only one file in the /var/local/ucs folder and its config.ucs, its 249,428 KB. Below is the output of df -kh
      Standby:In Sync] ~  df -kh
      Filesystem            Size  Used Avail Use% Mounted on
      /dev/mapper/vg--db--sda-set.2.root
                            427M  176M  229M  44% /
      none                  4.0G  2.2M  4.0G   1% /dev/shm
      /dev/mapper/vg--db--sda-set.2._config
                            3.2G  446M  2.6G  15% /config
      /dev/mapper/vg--db--sda-set.2._usr
                            3.3G  2.3G  821M  74% /usr
      /dev/mapper/vg--db--sda-set.2._var
                            3.0G  800M  2.1G  28% /var
      /dev/mapper/vg--db--sda-dat.share.1
                             20G  3.1G   16G  17% /shared
      /dev/mapper/vg--db--sda-dat.log.1
                            485M  253M  207M  56% /var/log
      none                  4.0G   34M  3.9G   1% /shared/rrd.1.2
      none                  4.0G  9.4M  4.0G   1% /var/tmstat
      none                  4.0G  1.2M  4.0G   1% /var/run
      prompt                4.0M   24K  4.0M   1% /var/prompt
      none                  4.0G     0  4.0G   0% /var/loipc
      /dev/mapper/vg--db--sda-app.ASWADB.set.2.mysqldb
                             12G  820M   11G   8% /var/lib/mysql
      [jim.couch@ptc-tf5-v02:Standby:In Sync] ~
    • RaghavendraSY_7's avatar
      RaghavendraSY_7
      Your /var partition and /usr partition is having very less space. You need to cleanup the files or increase the space for those partitions
      Jim_Couch_16225
    • RaghavendraSY's avatar
      RaghavendraSY
