on 03-Feb-2011 07:28
I got a request yesterday morning to asking if there was a way to drop HTTP requests if a certain number was referenced in the Accept-Language header. The user referenced this post on Exploring Binary. The number, 2.2250738585072012e-308, causes the Java runtime and compiler to go into an infinite loop when converting it to double-precision binary floating-point. Not good. Twitter is ablaze on the issue, and there is a good discussion thread on Hacker News as well. So how do you stop it? At first, this appeared to be a no-brainer, just copy that string and drop if found in that header, right? Well, there’s a catch. A few actually. This number can be represented in many ways:
String match seemed the perfect fit for this as I need a few wildcards to sort this out. I started in the Tcl shell just to make sure all the use cases matched:
